atulthummar
Please wait while Window configures..Pop up
We have successfully installed application at client ends, but some time when user interact with the client application at that time shows the pop up dialog with warning "Please wait while Windows configure your application" for more detail review the attached images.
kindly inputs on the same.
Atul
Re: Please wait while Window configures..Pop up
Hi Atul,
There are two situation when this dialog is shown:
- Windows Installer detects that there are some missing or modified resources in your application
- one or more feature in your application are set as advertised in the Organization page. In this case they will not be installed until the application needs them.
Also, you can read about this problem in the File Associations - Please wait while windows configures thread.
atulthummar
Thanks for your inputs, we will review and let you know if found any issues.
atulthummar
In Event Viewer we have following waning message
Detection of product '{7E4C87FE-4FE6-44A3-8C34-642090C7D52B}', feature 'MainFeature' failed during request for component '{6BC481DC-ECE7-46D9-8572-C6F13629D08F}'
I have attach .aip file can you please help for the same to resolve issues.
Installer.aip
(123.51 KiB) Downloaded 640 times
Exactly as I said in my previous post Windows Installer detects that the component '{6BC481DC-ECE7-46D9-8572-C6F13629D08F}' is missing and it first repair or recreate this component in your application folder and then run the application.
Please keep in mind that the missing component is found in the application folder (the folder where your application were installed) not in your .AIP (project file), the project file is configured correctly. This happened because after the application was installed, that component was modified/removed manually by the user or automatically by the application.
You can get rid of this pop-up dialog by going in the Organization page, select the component related to your file associations, move it in its own feature and check the "Disable advertise" option from the "Advertise Settings" group for that feature, but in this case the "Auto repair" feature will be disabled and you'll get an error if you try to run the application and some resources are missing.
atulthummar
Thanks for your valuable inputs.
You're welcome. Glad to help.
