jeronimobertran
Long Product Name Truncated on Surface Theme
We are evaluating your product and while testing we noticed that with a long product name, the surface theme shows the name fine on two lines on the preview but when we run the setup, only the first line is displayed. I am enclosing an image with both cases.
Is there any way to make the installer show the second line?
Advanced Installer Themes.png (92.22 KiB) Viewed 5238 times
Re: Long Product Name Truncated on Surface Theme
Hi and welcome to Advanced Installer forum.
I've tested your scenario, but I cannot reproduce the behavior. Can you please tell us the version of Advanced Installer and the Operating System you have on your machine and also a step by step test case scenario so we can try to reproduce and investigate the problem?
jeronimobertran
Hello Eusebiu,
I am using WIndows 7 Ultimate, 64 bit. Advanced installer 9.9 build 49525.
The steps to reproduce, I just create a New from the Professional Template, set the Product Name to My Long Product Name, change the Theme to Surface black and build the project.
My screen resolution is 1920x1080 and I thought it may be a DPI issue since I normally have it at 96 DPI but changing it to 120 DPI didn't solve it.
This is an Advanced Installer limitation in Professional projects which is resolved in Enterprise projects where you can edit the Dialogs.
If you don't want to upgrade to Enterprise license you can send us the .AIP (project file) to support at advancedinstaller dot com and we will modify it for you.
