atulthummar
Organization Page creating multiple entries
ISSUES #1 : I have shown on Organization tab it creates multiple entries.(Attach image 2.jpg),As I have .NET DLL in File & Folder application from there I have select the Option for "Register .NET assembly for COM Interoperability " as attached in image(1.jpg)
ISSUES #2 : On Updater page , Update execution there is facility to configure task, so that we have configure Task. but my issues is that when Uninstall the application it wan't uninstall Task Scheduler from machine.....
Kindly suggest on the same.
Atul
Re: Organization Page creating multiple entries
Hello Atul,
Please keep in mind that the "Register .NET assembly for COM interoperability" option creates, in the "Registry" page, the required registry entries in order for your assembly to be operable through COM. Also, the above registry entries are added to the component of your .dll file.
I've tested your scenario, using version 9.9 of Advanced Installer, but I cannot reproduce the behavior. Can you reproduce the behavior on multiple clean machines? If so, can you give us a detailed step by step test case scenario so we can try to reproduce and investigate the behavior? Also, if you want you can create and attach a sample which reproduces the behavior.
atulthummar
For ISSUES #1, So why it's create MPDatanotifier.dll,MPDatanotifier.dll_1,MPDatanotifier.dll_2......I have only single DLL.
Give me your input so i can make changes.
ISSUES #2..We are testing on V9.7
I'm not sure why you are encountering this. Can you send us the .AIP (project file) of the installation to support at advancedinstaller dot com so we can investigate it?
I've tested your scenario using version 9.7 of Advanced Installer, but I cannot reproduce the behavior. Can you attach a sample which reproduces the behavior or give us a step by step test case scenario so we can try to reproduce and investigate this?
