tgillitzer
IIS https binding on specific IP address
In AI 9.9, I am unable to create an HTTPS binding if I specify an IP address. If it tell it to use all available IPs, it works just fine.
I'm installing on a Windows 2008 R2 system.
Re: IIS https binding on specific IP address
Indeed, this seems to be an Advanced Installer limitation. A fix will be included in a future version of Advanced Installer, thank you for bringing it to our attention. Until then, as a workaround you can use a fixed version of our iis.dll file. Just replace the original one from the install folder of Advanced Installer (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 9.8\custact\x86) on your machine and rebuild the package.
This was fixed in version 10.0 of Advanced Installer released on March 21, 2013.
