valiot
Error while creating scheduled task
My installer is a 32bit installer. Not sure if this matters. I'm installing a scheduled task as part of my install.
Recently a user received this error message while installing on a 64bit system:
Any idea what I'm doing wrong?
Re: Error while creating scheduled task
I'm not sure why this happens. Can you attach a sample project which reproduces the behavior or a step by step test case scenario so we can try to reproduce and investigate this? Also, can you please tell us what is your target machine software configuration (i.e. Windows version, service pack, Windows Installer version, OS language)?
valiot
This happened on: Win7 64. My app is 32bit app. This also happened on Win8 Pro x64. English OS in both cases.
I'll attach my aip file offline through email support.
This was on a customer machine so it's hard to get more info. I cannot reproduce it myself, but the customer can reproduce it on both system types indicated above.
We did some digging and were able to reproduce the problem. This happens because of the API used by Windows Installer to create the scheduled task. You can change that API from "Task" tab when editing the task in Advanced Installer,
just select "Windows Vista, Windows 7" for the task.
If you want the task to also be created on older OS-es you need to add a new identical task in the list, and for both of your tasks you need to set the "Install Condition" field so only one gets installed. The following article explains how to create your OS dependent condition.
valiot
Hmm, I tried this configuration but it didn't solve the problem. This is related to the task scheduled for the updater if that makes a difference.
valiot
Also, I'm trying to reproduce this issue on a virgin Win8 machine but cannot. So I don't see how this error is happening. Is it related to the Windows Installer version?
valiot
Also for OS version check. If I want to run the task only on vista and greater systems should I use the following? VersionNT >= 600
We've tested the scenario, but we are not able to reproduce the behavior using a task configured for "Windows Vista, Windows 7". Did you reproduce the related behavior using a task configured for "Windows Vista, Windows 7"? If so, can you isolate this in a sample project and send it us so we can investigate?
Yes, if you want to install it only on vista and greater OSs you should use this condition:
  • VersionNT >= 600
