bchetana
xml file merge on update
At the time of installation we will ask the user to select the working folder. This shall be stored in
an XML file which will be stored in installation folder. This XML file is set with following settings [pleas c the images attached]
I am having a problem with this approach
when We install the upgrade we will first uninstall the old version and then we will install the update using /br [no UI].
The application shall be using the same config file to get the working folder, as it is not updated. [which is fine]
But when we uninstall the old product and then install it as fresh installation, the user shall be asked to select the Working Dir. In this case
as it set to not update, AI is not updating the file. So I want to differentiate the two scenarios [update, fresh install]. How can i condition the XML update?
Aslo for every install, uninstall .BAKE files are created. How can i clear them ?
ScreenHunter_02 Feb. 18 11.50.gif (27.49 KiB) Viewed 3804 times
ScreenHunter_01 Feb. 18 11.49.gif (29.21 KiB) Viewed 3804 times
Re: xml file merge on update
You cannot set a condition on part of an XML file, but you can set one for the entire file, by setting the condition on the component that installs it, in Organization page.
You will need to create to identical XML files, and install them as explained in this article.
Then you need to locate their components, press F8, in Organization page, to set the condition. For an upgrade the condition should be "OLDPRODUCTS", for a fresh install it should be "NOT OLDPRODUCTS".
Also for every install, uninstall .BAKE files are created. How can i clear them ?
In the screen-shot called "ScreenHunter_01 Feb. 18 11.49.gif" you can see an option called "Create backup before updating", disable it.
bchetana
Hi
I did as you suggested.
Before upgrade we first uninstall the existing product and then we Install.
As a result, the above mention logic is not working. The condition "OLDPRODUCTS" is not getting executed. How to handle this?
If you uninstall separately the old version of your product, and don't uninstall it during installation of your upgraded version, then you can create a search which should detect if an older version of your product was installed on target machine. For example you can add a registry value in your projects which will not be removed during uninstall. Then, in "Search" page you can add a registry search which will search for the above registry value.
