bchetana
same registry key - 32/64 bit
Hi ,
I have a problem in creating the same registry key which loads on a condition
I have two com exposed dll's. One for 32bit and one for 64bit which shall have the same registry entrys after installtion. This is conditiond to office bit.
To do this, I did in following way:
Ist am loading the 32bit dll and registering it to "RegisterCom -> Registration ->Edid File" option from files and folder. After doing this all the registery entries are registerd. Now from Install Parameters page i am creating a custom property for each of the entry as said in following loaction
http://www.advancedinstaller.com/user-g ... istry.html
Now I am adding these keys in regisry. Please see the following image for info. Then moved all the 32bit entries to these keys.
Now I am loading the 64bit dll and registering it to "RegisterCom -> Registration ->Edid File" option from files and folder. After doing this all the registery entries are registerd. [the compleate pic is in attachment]. All is fine till now. But onece i buld the project all the 32bit keys are not loaded . Why this behaviour ?
How can i over come this issue ???
ScreenHunter_03 Feb. 22 10.23.gif (8.16 KiB) Viewed 7872 times
ScreenHunter_02 Feb. 22 10.20.gif (6.03 KiB) Viewed 7873 times
ScreenHunter_01 Feb. 22 10.20.gif (36.46 KiB) Viewed 7873 times
Re: same registry key - 32/64 bit
Can you please disable the registration synchronization for the related dll files and see if the behavior still persist?
bchetana
Ya did it..
Still the issue persist...
Can you please try the following scenario:
- delete all the extracted registry entries, in the "Registry" page, of the related DLL files
- remove the above DLL files from "Files and Folder" page, then add them back
- enable the 32-bit DLL "Auto register file" option with the synchronization disabled
- move its extracted registry entries under property-based registry key
- enable the 64-bit DLL "Auto register file" option with the synchronization disabled
- build your project
and see if the behavior still persist? If so, can you please send us the .AIP (project file) and a download link of the related DLLs to support at advancedinstaller dot com so we can investigate them?
bchetana
ThnQ.. This time it worked,
I was enabling synchronization option. So faced the issue.. Thnq
bchetana
Hi
How can I achive this by enabling the "registration synchronization for the related dll files ". I need this for auto updates... how can I achive this... ???
Unfortunately, you cannot achieve this when the registration synchronization is enabled.
