jfuhr
Creating a help button
On one of my dialogs, I want to add a help button to provide the user with more information.
I thought I could use the MessageBox custom action, but I can't figure out how to get this to work.
The tutorial says to add the message string to "Action Data", but I do not see this field in the DoAction event.
Here is what I have done so far:
Added messagebox to custom actions.
Added a button to the dialog.
Added a published DoAction event and referenced MessageBox.
After this I'm stuck.
Ideally I would like to open a web page instead of showing a message box, if that is possible.
Re: Creating a help button
In order to achieve what you want you can use one of the following solutions:
First:
- go in the Custom Actions page and create a "Display message box" custom action without sequence
- in the "Action Data" text field from the right pane add your message string
- go in the Dialogs page and add a "Push Button" control on the dialog you want
- select the button you added and create a new published event
- in the "New Control Event" dialog choose "Execute custom action" and select your "Display message box" custom action from the "Argument" combo box
Second:
- go in the Dialogs page and add a "Hyperlink" control on the dialog you want
- in the "URL" text field from the "Properties" pane write the link to your help page
Third (this opens a web page when you press a button):
- go in the Custom Actions page and create an "Execute inline script code" custom action without sequence
- in the "Script Text" text field from the right pane add a code like in the example:
CreateObject("Wscript.Shell").Run("www.mysite.com")
- in the "New Control Event" dialog choose "Execute custom action" and select your "Execute inline script code" custom action from the "Argument" combo box
Let us know if this helped.
