PKRU
How i can get STDOUT from VB6-EXE as result in variable
Hi ,
sorry, but i'm very new in advanced installer, but i have a life problem.
i need the STDOUT from a vb6-exe that i call with parameters as result in a custom variable i created in advanced installer MSI package. How i can do this in vbscript in installer?
Thanks for helping.
Peter
Re: How i can get STDOUT from VB6-EXE as result in variable
Hi Peter,
I am not sure how to get the output from your EXE in VBScript, but for this I am sure you can find samples of code on Google.
Once you get the output you can set a public property with it, so you can use it in the installer, like this: http://www.advancedinstaller.com/forums ... =2&t=10194
PKRU
Bogdan wrote:Hi Peter,
Hi Bogdan,
thank you for helping. I'll try to implement this in next few days and give back any status.
Have a nice week.
Peter
