Vicente
Problem with skin in machines where screen has zoom
Hi!
we have found in our installer that if the user has set the "Change the size of all items" property on Windows (Control Panel -> Appearance and Personalization -> Display) bigger than 100%, then our installer looks like in the attached image. Is there any way to fix this?
Regards!
21-02-2013 14-08-05.jpg (75.67 KiB) Viewed 2322 times
Re: Problem with skin in machines where screen has zoom
In order to achieve what you want you should enable the "Stretch images to fit their controls" option from "Themes -> Settings" tab.
