bchetana
Repair from Add-Remove programs
Hi
We are giving the option of Change/Remove from the control panel - >Add or Remove programs. When we click on Change we get the options to Modify, Repair and Remove. When we select Repair for the first time its going on with out any error. But for the second time if we select repair following error pops up... How can i overcome this behaviour ???
ScreenHunter_01 Mar. 04 14.45.gif (189.97 KiB) Viewed 7000 times
ScreenHunter_02 Mar. 04 14.45.gif (126.96 KiB) Viewed 7000 times
ScreenHunter_03 Mar. 04 14.46.gif (9.51 KiB) Viewed 7000 times
bchetana
Re: Repair from Add-Remove programs
The setting in AIP is as bellow
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention. Until then, as a workaround you can enable the "Do not delete the extracted MSI and CAB files" from "Media -> Configuration" tab.
bchetana
ThnQ for the workaround
You're welcome. Glad to help.
This was fixed in version 10.1 of Advanced Installer released on May 2, 2013.
