goset
Client/Server install
I am trying to build a client server in stall for my program. I have set it up to browse and then run sql scripts but I would like to only have it run on the server side. I have the sql scripts to run only at this side for server but it keeps looking for server information and I was hoping to not have that part on the client side. Could anyone tell me a why to keep the brower for server part not required for client installs please.
Re: Client/Server install
I'm not so sure what is your scenario. Can you please send us the .AIP (project file) so we can investigate it and try to find a solution for you?
goset
Where would you like me to send this to?
The scenario is a client/server all in one install. I have the person select the client or server button and when they hit server button they need to have selected the server database path in the drop down. This drives the sql scripts install part of the install. Well even with the client button clicked it still is requiring them to select a server in the drop down. I dont have any sql scripts running when its client but I can not figure out, how to not require the data base server selection from drop down on client.
Attached is the screen I am trying to configure.
You can send your .AIP to support at advancedinstaller dot com.
