remya5151
Server Side Validation
hi
i am using server side validation in adavance installer to create a msi for a java application. but problem is that nothing is happening after getting the server response. an alert is showing.even the serial number is right,screen do not proceed to next one.. what will be the reason? please help
Re: Server Side Validation
Thank you for your interest in Advanced Installer forums.
I'm not sure why you are encountering this behavior. Can you try to debug your script (which does the validation) and see if it returns an answer like this:
601\nMessage
Your script validation should return a 601 answer code in order to validate the serial number. Please take a look on our "Configure server-side serial number validation" article.
