toschlog
Comments displayed instead of Program Name in UAC dialog
For one of my projects, when the UAC dialog comes up the comment property is displayed where the program name should be. See attached.
Any idea what's happening?
Re: Comments displayed instead of Program Name in UAC dialog
This may happen if you are using the ARPCOMMENTS property in your EXE name or in the embedded MSI name. Can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it?
This also happens if the "Description" field from Digital Signature page is not filled in. Can you please set there the desired description for your package, rebuild it and try it again?
