regant
Error Importing WiX project
We recently purchased Advance Installer 9.9 and I am attempting to start by importing our existing installation. I choose the Import->WiX project and get the import wizard. I then select the project and press the "Next>" button. It begins working and then I get an error stating "The application ran into a problem that it couldn't handle. Sorry for the inconvenience".
Is there any way to find out what the problem is so that it can be addressed? This error is a bit vague.
Build Machine: Windows 7 Enterprise
Visual Studio: 2010
Advanced Installer 9.9
Re: Error Importing WiX project
Hello Regan and welcome to Advanced Installer forums,
We've received your Wix project sent to support at advancedinstaller dot com. Please give us some time to investigate this and we'll get back to you as soon as we have a conclusive answer. Until then, as a workaround, you can try to import the MSI package built by the related WiX project.
Hello Regan,
After further investigation, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
This was fixed in version 10.1 of Advanced Installer released on May 2, 2013.
mogikanin
i have the similar problem. I'm tried to import existing wix project and get error: "*.wixproj cannot be accessed. Please verify that the corresponding Visual Studio module is installed or that the project exists".
I'm using VS2012 and AI 10.3.
Maxim.
Screenshot
Screenshot
Hello Maxim,
Can you please make sure that you have a version of WiX Toolset (compatible with Visual Studio 2012) installed on your machine and see if the behavior still persist?
mogikanin
Hi Daniel,
yes the WiX toolset v3.7 is installed, and i can create/edit/build wix projects in visual studio 2012.
If it helps, i can send you my wix project.
Maxim.
Hello Maxim,
First of all I apologize for my delayed reply. Can you please send us your WiX project to support at advancedinstaller dot com so we can investigate it?
mogikanin
Done.
Hello Maxim,
This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing this to our attention. Until then, as a workaround, you can check the "I don't have a WiX Visual Studio project file. I'll pick the source files manually" option from "WiX Import Wizard" dialogs and then manually add your fragments files.
