remya5151
Editing Properties file using VB script
hi
is it possible to edit a user defined properties file in advanced installer?i am able to edit text file but couldn't edit a property file.how it can be done?
Re: Editing Properties file using VB script
I am not sure I understand correctly your question. What is it different between a properties file and a text file, except the file extension of course? Basically you can use our Text File Updater for any file type, i.e. plain text, INI, XML, etc..., to update it using the Find and Replace mechanism provided by us.
