bchetana
Multilingual package installations
Hi
We are going to put the link to our installer on our website . Based on the customer language that has logged in, we need to start the installer in that language. The installer may be download or run from browser.
I have build the Multilingual package to support this. So how to instruct the browser to run the package directly with that command line (example :/exelang 2070) ???
I tryed the following but dnt work,
http://www.mycompany.com/myProduct.exe? /exelang 2070
How to handle this ?
Re: Multilingual package installations
You don't need to instruct the browser to do that, you can instruct our installer to detect the system language. Just go to Translations page and enabled this option from there.
When launched the installer will automatically use the same language as one of the system, if this language is not in the package it will use your default project language.
bchetana
Hi
I have the following settings in my installer.
But My requirement is, the installer language should purely depended on my website language. It is must.
So how can I do this ? How can i give parameters to my download link ???? Or can i give run time parameters to the installer which will start the installer in the given language?
ScreenHunter_01 Mar. 20 11.32.gif (5.25 KiB) Viewed 6110 times
I'm afraid we don't have support for this.
I'm afraid I'm not aware about a solution for this scenario. Also, you can take a look on our "Passing parameters to installer Name ... ??" thread which debates a similar issue.
In order to achieve this you can run the installation package from command line using a command line like this:
myProduct.exe /exelang 1033
bchetana
Hi
When I give "scc.exe /exelang 1043 " it is working fine...
I also want to set my public properties something like "scc.exe IS_PARM_1=test IS_PARAM_2=test2 /exelang 1043
When i give like this, the public properties are taking the inputs but exelang is not ...How can i do this?? Am I making anything wrong?
In order to achieve what you want you should use a command line like this:
scc.exe /exelang 1043 IS_PARM_1=test IS_PARAM_2=test2
