lackofaname
Repackage installer
Hello All.
I am trying to use a capture to package an MSI.
After the capture runs and creates the project, I am noticing a lot of "junk" that I would not want to include in the package.
How do you remove the components from the feature?
Re: Repackage installer
A non-empty component cannot be removed. So, in order to remove a component you must first remove the files it contains. You can find a component's file by simply selecting it and pressing the "F8" keyboard button.
Note that it is very recommended to start the installation capture in a clean virtual machine. Also, you can create your own profile by going in the "Application menu" -> "Options" -> "Repackager Settings" and in the left pane choose "New" from the context menu.
Let us know if this helped.
