Max L.
Surface Theme incomplete
i bought the advanced installer enterprise. Now i want to use the Surface theme. It that theme incomplete? Because if you use the black edition the tabs are white an looks ugly. Is it possible to change that. If yes, how?
-Max
Max L.
Re: Surface Theme incomplete
One more question. :)
1.) Where to find informations how to create a theme from scratch?
2.) How the change checkboxes etc. Because in the surface theme the checkboxes doesn't match the theme itself.
3.) Is there is list of propertys? http://www.advancedinstaller.com/forums ... 869#p57506 I've seen this thread. How do you know that this property has to be used?
4.) I want to design my own dialogs in Photoshop to get an empression of sizes etc. Can i bring that to the advanced installer?! So do i have the freedom to do everything?
5.) How do i change the color and style of the progressbar?
6.) How do i change the color and style of a listview?
This may happen if you enabled the "Keep original image sizes" option from "Themes -> Settings" tab. Can you please enable the "Use individual control 'stretch' settings" option and see if the behavior still persist? If so, can you attach a sample which reproduce the behavior so we can investigate it?
In order to achieve this you can use our "Dialog Editor" feature.
You can edit or change the images, from "Themes -> Images" tab, associated with checkbox, AI_TREE_CHECK_BOX_IMAGES and AI_CHECK_BOX_IMAGES properties.
3.) Is there is list of propertys? viewtopic.php?f=2&t=22869#p57506 I've seen this thread. How do you know that this property has to be used?
Please take a look on our "Custom window chrome" thread which should be useful for you.
Yes, you can change the background and banner images from "Themes" page.
Please take a look on our "Progress bar color change?" thread which debates a similar topic.
For this you can add a new text style on "Themes -> Text Styles" tab. Then, on "Dialogs" page add a list view control and from "Properties" right pane set the "Text Style" section like this:
  • Use Indirection: True
    Indirect Property: Custom_Text_Style
Max L.
Thanks for your answer. I getting more into it. What i've done is, i choose the spring theme an changed a bit. Now i have a small bug. If i click a bit around no text is shown (maybe only not the background image). An every time a i click a round it is flashing a bit.
One more. Is it possible to change the icons (arrow and the little pc or "X") and positions in the list. it is a bit narrow for me.
Max L.
One advice. If i run the in installer with log, then a i can't reproduce it. Without log one or two clicks i have the error.
I'm not sure why this happens. Can you attach a sample (.aip file and all necessary files to be able to build and test it) which reproduces the behavior so we can investigate?
Yes, you can change and edit its corresponding images from "Themes -> Images" tab.
