Zanele Khumalo
Installation of Application
I tryed to do set on Advance installer and i also did all setting but when i tryed to run my Project its give me File error. How cajn i solve this please give me instruction of how am i going to solve this problem
The error is COuld not write value ErrorControl to key then its specify the file. Then said ensure that you have key access. I tyed to delete that file but still keep on appearing
gigi
In oder to investigate the problem please send the AIP file (if not contain any confidential informations) or a small similar test case reproducing this issue to support at advancedinstaller dot com.
Also please generate a log file while running the package and send it to us. To obtain the log file run the package with following command line:
msiexec /i package /l*v package.log
Gigi
______________
Gheorghe Rada
Advanced Installer Team
Return to “Feature Requests”
