fdzuno
Dynamic Folder Name based on user input value
Need to install files into a custom folder under the main install directory
Custom folder name must be specified by a user - in a custom dialog via input textbox (custom property called ISI_PROP_SYSTEM_FOLDER)
ISI_PROP_SYSTEM_FOLDER default value is set to System2
Properly configured a property-based folder pointing to the ISI_PROP_SYSTEM_FOLDER property.
Example:
I need to install all my configuration files in C:\Program Files\[CompanyName]\[ProductName]\[ISI_PROP_SYSTEM_FOLDER]
However, when install runs and user enters value into the ISI_PROP_SYSTEM_FOLDER textbox, the folder name is not named according to the user input. Instead, a new folder called "System2" is created -the default property value.
If I display the value of the property in a messagebox, the correct value is displayed.
Followed the http://www.advancedinstaller.com/user-g ... older.html, spent 2 days on it already, no success.
Frank
Re: Dynamic Folder Name based on user input value
Hello Frank and welcome to Advanced Installer forums,
Please keep in mind that this happens because you've used the related property name as a PseudoFormatted data type (which is resolved at build time) in the folder name.
In order to create a property-based folder you can take a look on our "Folders" article.
Here's attached a sample, created using our 10.0 version of Advanced Installer, which implements a similar scenario.
sample.zip
(2.88 KiB) Downloaded 221 times
fdzuno
Unfortunately,
I do not have version 10. I just bought version 9.9 - just couple days before you released the version 10 :( .
Obviously, I got an error when I tried to open the sample.
Could you please send me the example in the 9.9 version?
Frank
Hello Frank,
Please note that each Advanced Installer license purchase includes a free 6-month maintenance plan. So, if your maintenance plan it is valid you can download and register our last version of Advanced Installer. You can check if your maintenance plan is valid from our Maintenance Plans page (just enter your license key).
Here's attached a sample, created using our 9.9 version of Advanced Installer, which implements a similar scenario.
sample.zip
(3.04 KiB) Downloaded 198 times
Let us know if you have an questions.
Daniel,
fdzuno
Thanks a lot for your help. It worked . Maybe you should think of adding it to your help topics. I can imagine a lot of users have the same requirements.
It was not 100% clear from the documentation. I actually followed the instructions and tried to make it happen for 2 long days.
Again, I am impressed. Thank you, Advanced Installer. Btw., I was able to upgrade my installer version to the latest version based on your instructions. Thanks for the info.
Frank
Hello Frank,
We already have an article (Install files in a custom folder) which debates a similar issue. However, we'll consider this in a future version. Thank you for your suggestion.
