valiot
How to hide command prompt windows (custom actions)
I have several command line custom actions I'm doing. However, they popup some ugly command prompt windows. Is there a way to run the command line actions with these windows minimized or hidden?
Re: How to hide command prompt windows (custom actions)
You can follow the How do I hide the command window of a custom action article. Another way to do this is described in the running batch file in backgound thread.
valiot
If I have switches to run with the EXE, how do I specify them? It's not described in the help doc.
You can write your switches right after your file name in the "Action Data" text field like in the example:
[#MyFile.exe] /switch1 /switch2
valiot
I'm having problems with this. It's not working. I'm trying to call a temp file:
[Manufacturer_Dir]>[&txtedit.exe] /switch
I've tested your scenario and everything worked well to me. Can you please send us the .AIP (project file) and a verbose log of the installation so we can investigate them?
It might not work if you do not run your custom action as "deferred" with "no impersonation".
valiot
I found the cause of the problem but I don't know how to fix it.
If I run my installer on a clean machine it works fine and the command line actions execute. However, they do not execute if I am upgrading a previous version of my app.
I was monitoring the folder where the temporary file is placed. I notice that the temp file was created at the start but was removed at the end of the uninstall process of my previous app. It was never put back. So this is why the command-line did not run in my installer because the temp file was not there (it was deleted by uninstall process). So how can this happen and how do I fix it?
Indeed, this happens when the old version of the product is uninstalled. To overcome this you can follow the steps below:
- in your [Manufacturer_Dir] folder create a new folder named [|ProductVersion] and move your temporary file in it
- then in the "Action Data" text field of your custom action you can use the following string:
[Manufacturer_Dir]\[ProductVersion]>[&txtedit.exe] /switch
Let us know if this helped.
valiot
Strange. [|ProductVersion] does not resolve during install. It just creates a folder called ProductVersion.
valiot
Ok, I fixed the issue. I deleted the folder and re-created it and now it resolves correctly. But now the command doesn't run.
BTW, I had to change the action data to:
[Manufacturer_Dir][ProductVersion]\>[&txtedit.exe] /switch
Because the [Manufacturer_Dir] contains the trailing slash but [ProductVersion] does not.
Can you please try the command I wrote in my previous post or even a command that doesn't contain any slash character and see if the behavior persists?
