My company just purchased Advanced Installer 10 Enterprise and I've been tasked to learn and build an installer for a project. The requirements of the installer are as follows:
- Check the registry for 3 different values.
- Use the values from the search for a conditional logic (If X, Y and Z = 1, perform file copy from location A to program dir).
- Based on the conditional results, copy files from location A to program dir.
After reading through the forums and documentation, I have gathered the following sequence:
Use the Custom Behavior Search function to search for one of the registry values which will be the search result used in the Organization Condition field to determine which file is copied. The challenge I'm running into is when defining the registry value; when I use the "New Search" wizard and get to the point where I select the "Key" using the "..." button the field doesn't update with my selection and if I type it in, the search test fails. Also, where do I define what directory the files should be copied to based on the conditional value results? Any help would be appreciated.
Derek
