ddsharper
How can I send an email to the user during installation
What I want to do is use an exe file, in the dialog sequence during an install, from a send-email app/page I authored in vb 2008- that will pop up or and require the end user to enter their name and email address. I would then send them the serial number, so after the welcome dialog, the next page would direct them to a dialog page containing a button, and then the vb app would pop up, they'd fill it out, and once it closed, they'd click next, and be taken to the enter serial number page. I couldn't find it again, but I thought I ran across a page where an executable could be used in the dialog sequence for a new install.
Re: How can I send an email to the user during installation
A similar problem was discussed in the Starting installed program with push button thread. Please check that answer and let us know if it help, otherwise give us more details about your scenario.
ddsharper
if i were to do this with the vb app i wrote, where would i put it so it shows up on the end users computer too. it seems to me that if it's in the application folder, it too would be compiled with the main app. hope this isn't a dumb question.
Sorry because I forgot to mention that you can use a "Launch attached file" custom action instead of "Launch installed file" custom action and also you can add your application in the "Application Folder" if you want it to be installed on the users computer too.
Let us know if you have any other question.
ddsharper
thank you, but if you do not want it to be installed on the end user's computer, which folder would you put it in?
If you do not want it to be installed on the end user's computer you do not have to put it in any folder, just use the "Launch attached file" custom action and your VB application will be embedded in the MSI package to be used by the custom action when needed, but it will not be installed on the user's computer.
You're welcome. Glad to help.
ddsharper
custom action does not show up in dropdown. did a launch url custom action. and how do I find viewer.exe.
Can you please give us more details about your issue?
ddsharper
http://www.youtube.com/watch?v=DXtY4rx24BU&ns=1
I used the wizard of custom actions to create an action to open a url that I want to attach to the push button in a dialog. Here is a brief video of not seeing the action in the dropdown.
This happens because your custom action is added "with sequence". So, is is displayed in the "Installation Sequence" pane and is called after a specific standard action, but you can't use it in the Dialogs page as a published event.
In order to be able to use your custom action in the Dialogs page, you need to add it without sequence as shown in the image below.
Custom Action.png (36.56 KiB) Viewed 13087 times
ddsharper
Thank you; it worked.
