shetty_rohan
Grey background behind the "Lauch Applcation" label
I have a setup, in which I have used the following
- In themes->User Interface -> Use Enhanced User interface->Never
- In themes->Bitmaps Display->Stretch images
- In "Exit Dialog"->Launch is enabled
Now when I execute the setup, I would get the grey background behind the "Launch application". Is it possible "not to get the grey background"?
Grey background
Grey background
Note:
- If I use "Enhanced User Interface", I do not get the grey background. I need to disable the "Enhanced UI" because of some known bugs(like installation folder not getting removed)
- I can not reduce the size of the control, because I also support multiple languages.
Re: Grey background behind the "Lauch Applcation" label
Hi Rohan,
This happens when you add a checkbox on a white dialog like "ExitDlg", because the "Check Box" control does not support the "Transparent" flag. You can use our predefined "Launch Application" checkbox which will be displayed correctly.
shetty_rohan
Thanks.
Now, I understand the problem. We had a requirement to support the "click on the text next to the checkbox" should select/deselect the checkbox. This used to work fine when we had "enhanced user interface".
In the simple user interface(i.e "enhanced user interface" -> never) is it possible to support "Click on the text next to the checkbox should select/deselect the checkbox"??
Yes, it is possible to select/deselect a checkbox only by clicking on the text next to it, even if the "Enhanced User Interface" is disabled, but as you have already seen, the label of the checkbox has a gray background because this is a Windows Installer limitation.
Unfortunately, the only solution is to enable the "Enhanced User Interface".
shetty_rohan
Thanks for the update.
There were couple of issues in the "enhanced user interface" like http://www.advancedinstaller.com/forums ... =5&t=23179 and http://www.advancedinstaller.com/forums ... =5&t=23196 because of this I had to disable the "enhanced user interface".
Anyways, once the "enhanced user interface" problems are solved, I will enabled the "enhanced user interface" in my project.
You're welcome.
