emrey
Layout / Resolution Problem
We have tested our installer on Windows XP and above operation systems. We never had a problem like attached.
Our customer sent us this problem, Operation system is Win 7, resolution is 1920x1080.
All layouts are broken down.
Do you have any ideas? What can cause to this problem?
EDIT:
We realized that users Display Option is set to Medium %125. This is the reason of problem. What can we do for not to effect by display option?
Thanks a lot,
regular layout
regular layout
layout problem
layout problem
Re: Layout / Resolution Problem
To overcome this problem you can go in the Themes page, "Settings" tab and select the "Stretch images to fit their controls" option.
Let us know if this helped.
emrey
Thanks a lot for the reply.
Background image size was fixed. We set fixed=false for all background images.
