valiot
Error trying to update from setup
I have the feature to check for updates from the installer on startup. However when the installer finds an update and I select to install it, I get an error message:
"Error: Overlapped I/O operation is in progress"
see image:
Clicking Retry is the same effect as Ignore.
Re: Error trying to update from setup
This may happen if you cancel the download of the newer version of your package or if the download URL of your upgraded package (from your server) is corrupted. So, can you please make sure that the "Download URL" field, from your update configuration project -> Updates page -> Properties tab, contains a valid URL and try again?
valiot
Thanks, I will check this and get back to you.
valiot
Well, that removed that error but a new error appeared.
It seems like the download proceeds until the end and then I get the following error:
If I select retry it goes through and repeats the download process and then jumps to the OLD installer!
If I select cancel it goes to the OLD installer.
So this is still very bad. Any suggestions?
I'm not sure why this happens. Can you please send us the following:
- target and upgraded .AIPs (project files)
- the .AIP of your updates configuration project and its built updates configuration file
- target and upgraded built MSI/EXE installation files
to support at advancedinstaller dot com so we can try to reproduce and investigate this?
valiot
I think I found the problem. The size of the download was different than what was specified in the updates.txt file. I built a new updates.txt file with the new download and now it works. I really wish you guys would improve the error messages so the client can understand why the downloads fail. It's not a nice experience.
I'm glad you got this working. We'll improve the above error messages in a future version of Advanced Installer, thank you for bringing this to our attention.
