jmedina
Issue with downloading files
I have two installers generated with advanced installer, both are different
products, each one of them has a merge module that contains one file named "prueba.xlst".
This file is an unversioned file and also has differences between creation date´s and modification date's in each product.
So then if I have already installed one product and I proceed to install the other "prueba.xlst" should not be overwritten. however, the file is always overwritten.
Does anyone know what kind of error?
image attached on the behavior of unversioned files.
Thanks in advance.
ArchivoForo.txt
log
(745 Bytes) Downloaded 320 times
rules
rules
Re: Issue with downloading files
In order to achieve this you can go in the Search page of your "Merge Module" project and create a new "File Search" to see if the "prueba.xlst" file is already installed by one of your products. Then in the Organization page you can use the search result to set a condition on the component that contains this file. In case the search is true (it found "prueba.xlst") the file will not be overwritten by the second product.
