rosen.nedialkov
Contact: ICQ
Is it possible to disable buttons on the AI dialog ?
Is there a sane way to disable buttons on the AI dialog ? I want to disable Cancel button when installing or uninstalling the product.
gigi
To disable a button on a dialog switch to "Dialogs" page, select the button and set "Enable" to false in the "Properties" list.
Gigi
______________
Gheorghe Rada
Advanced Installer Team
rosen.nedialkov
Contact: ICQ
gigi wrote: To disable a button on a dialog switch to "Dialogs" page, select the button and set "Enable" to false in the "Properties" list.
Is it for Enterprise version only? Because I have Professional license and dont have such Properties list.
gigi
Yes, the "Dialog Editor" is only available for "Enterprise" type of project (which requires an "Enterprise" license).
You can upgrade your license here:
http://www.advancedinstaller.com/upgrade.html
Best Regards,
Gigi
______________
Gheorghe Rada
Return to “Feature Requests”
