njshaw2
Left Pane search filter
Suggestion: When searching for "properties", include "Install Parameters" in the filtered results list, as that's where you can add/edit/delete properties. I took quite a while trying to find where to delete properties I didn't need, or wanted to edit after naming wrongly or added with incorrect default value.
Alternatively, could you allow the user to edit/delete properties from within the Properties popup dialog? You can add new user-defined properties here and it would be logical to allow r-click options to edit/delete them from here too.
Re: Left Pane search filter
We'll update the filter, thank you for your suggestion.
Regarding editing/deleting properties. You can do that from Install Parameters page, to what "Properties popup dialog" do you refer?
njshaw2
Hi Bogdon,
I mean anywhere where you can select a Property, e.g. when editing a condition for a new Control Event in a dialog, I can click "Property" under "Insert Operand" in the Edit Condition dialog. That pops up a "Select a Property" popup dialog. Example screenshot attached.
Thanks.
Example screenshot of the "Select A Property" dialog
Return to “Feature Requests”
