Skylla
Getting bootstrapper directory
Hello
Is it possible to get directory from where the bootstrapper is launched?
"SourceDir" cannot be used because the msi packages are included within the bootstrapper (and thus SourceDir is not the location of the bootstrapper, but of the extracted msi files)
Skylla
Re: Getting bootstrapper directory
Maybe i should add that i'm trying to create a log file in the directory where the bootstrapper is launched from
I tried setting the MSI command line to:
/lv [SETUPEXEDIR]install.log
But this does not seem to work
In order to achieve what you want you should set the "MSI Command Line" field, from "Media -> Configuration" tab, like this:
/L*V [SETUPEXEDIR]install.log
Also, you can take a look on our "Properties" article.
