bchetana
prerequisites .Net 4 and Visual C++ 2010 SP1 Redistributable
Hi
I have certain prerequisites like .Net framework 4.0 (dotNetFx40_Full_setup.exe) and Visuall c++ 2010 redisteributable(vcredist_x86.exe). they are added in the my installer in following sequence( C the pic bellow)
When main installtion is installed via GPO, this may happen silentely. So at that time(In the silent installation) I want to run these prerequisites aslo in the silent mode.
I tried setting "/q" in "setup files- Install command line -Silent" but dent work.
All the 3 prerequisites are added as .exe files. Is this a issue? How to handle this?
ScreenHunter_11 May. 01 16.06.gif (51.28 KiB) Viewed 4664 times
Re: prerequisites .Net 4 and Visual C++ 2010 SP1 Redistribut
When you add a prerequisite in the "Pre-install" folder, your main package is automatically set to an EXE package, but only MSI packages can actually be deployed through GPO. So, that could be the problem that your prerequisites are not installed correctly.
A similar problem was discussed in the GPO issue thread.
bchetana
My installer is MSI file. Can I move the .Net 4 to feature-based and give /q for silent commend line?
Will this be a problem?
Yes, you can. MSI packages can usually be installed as "Feature-based" prerequisites. I think ".NET Framework 4" prerequisite shouldn't be a problem.
