sjeslis
How To Get Merge Module's Version Into A Global Property?
I only see access to [ProductVersion] within the MSM. Is there anyway to set a property to "Module Version" either within the MSM or in the parent MSI containing the MSM?
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
Re: How To Get Merge Module's Version Into A Global Property
You need to do your own custom action. You can use a custom action written in C# or a custom action written in C++.
You can see in the Table Editor page, in the "ModuleSignature" the saving structure for the MergeModule Version.
You will have a custom action which will take from the ModuleSignature table the ModuleID and the Language as a unique identifier for the "Version" and set to a property. Set the “Property Name” to an appropriate name, let's say: “MODULE_VERSION”. You will use this Property Name in your code because this Property holds the version of your Merge Module.
sjeslis
Yeah I had a feeling that might be the answer.
Scott Jeslis
Cicero, Inc.
