xjluogang
How to track detailed installation progress
Hi guys,
most of installer can show the detailed installation progress in Listbox with dialog, like copy file, create directory, others, etc., can we do same thing with Advanced Installer?
I saw there only have few simple status showed on progress bar in ProgressDialog, how can we get more detailed informations? just like attached screenshot.
detailed install progress
Robin
xjluogang
Re: How to track detailed installation progress
any ideas?
Robin
xjluogang
Looks no response...
Can someone give me idea? Thanks a lot!
Robin
Hello Robin,
Please keep in mind that a corresponding action text (for all standard actions) will be displayed on "ProgressDlg" dialog (during installation). If you want to display an action text for a deferred custom action within your project, then you can use the "Action Text... " hyperlink under "Custom Action Properties right pane -> Execution Options" section.
Also, If you need to generate a log for your installation package you can take a look on our "How do I create an installation log?" article. Also, you can run your project within Advanced Installer application using the “Run and Log” item of the [Run] button context menu (from "Home" tab) or the “Project > Run and Log” menu item.
xjluogang
Hi Daniel,
Thanks for your reply. But I'm still a bit confused about "get detailed progress".
Looks like there only a few simple message has showed in "ProgressDlg". During the install process, AI actually have create folder, copy file into target machine. How can I get these information and show it in screen?
I can't find "Action Text" hyperlink, could you please give me more details? Btw, I'm use AI 10.0, and below is my screenshot.
Custom Action Prop
Custom Action Prop
Yes, I can see there many logs has output to AI console. but it's only for run the project within AI, and it's only for debug. How can I get these info during the real installation process?
Robin
Hello Robin,
Please note that when your installation package copy files on "ProgressDlg" dialog in the "StatusLabel" static text will be displayed the following message:
"Copying new files"
However, if your installation package doesn't contain a large number of files, then the "InstallFiles" action can be executed quickly and the related message cannot be observed on "ProgressDlg".
In Advanced Installer 10.0 you can see the [Action Text...] button in the bottom right side of the "General Properties" section from "Custom Action Properties" right pane. Also, please keep in mind that you can set an action text only for custom actions added as a custom action with sequence and scheduled to run as deferred.
I'm afraid we don't have predefined support for this. You can try to create your own custom action in order to achieve this.
The support to log installation actions during installer dialogs has been added in version 11.0 of Advanced Installer released on March 13th, 2014.
Here's the Display user friendly installation log tutorial which will guide you in displaying and configuring the user friendly installation log.
