thill
10.1 Custom Action GUI displays "Error"
Updated to 10.1 last Friday evening. Now several Custom Actions display "Error" in the top right-side panel area.
Screen shot of AI 10.1 error
SS_01 May. 05 14.08.jpg (119.46 KiB) Viewed 7484 times
This is AI 10.1 running on Windows 7 32-bit.
I have tried displaying the A010_... through Z999_... Custom Actions from project files as old a 4 months but AI 10.1 displays the same error. So I believe this is a software problem, not a data problem.
I will follow-up with an email referencing this post containing the latest project file.
Thank you for your time.
thill
Re: 10.1 Custom Action GUI displays "Error"
Also - Forgot to mention that I am not sure when this started. Have not been in that area of it for a while.
sjeslis
This started with 10.1 I believe. I was about to log the issue as well.
It's on all "upgraded" Custome Action types = 1 and source=aicustact.dll with target = "CreateExeProcess"
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
Thank you for bringing this to our attention, we shall have a fix for it ASAP.
Most likely this is a problem in loading the project on our side, you can continue editing the custom actions with version 10.0 until we release a fix.
thill
Bogdan wrote:... you can continue editing the custom actions with version 10.0 until we release a fix.
For my information, and the forum, is it possible to install 10.0 beside the 10.1 version?
Or does it require an uninstall/reinstall? That would take the license with it, so the re-install of 10.0 would require re-entering the license wouldn't it?
sjeslis
thill,
I know when you upgrade to a new version you can do a side-by-side install... never tried loading an older version on.
Nevertheless, the project AIP file has a version number in it... so in my mind I think we'd need to rollback to 10.0... I'm hoping I can workaround this and maybe a patch is incoming?
Scott
Scott Jeslis
Cicero, Inc.
You can also install an older version if a newer version is already installed. The license will be detected automatically.
Indeed, if you edited the license file and saved it with 10.1 you cannot open it with 10.0. However, when the project file is upgrade to 10.1 a backup is created next to it, so you can use that to edit in 10.0.
Or you can retrieve a previous version of the project from your repositories.
