MichaelQuint
Ensure that patches will not clear the InstallLocation value
We currently released a patch and noticed that after installing the patch the registry key "InstallLocation" value was empty, is there a way to when releasing a patch preserve the value for that key? The ARPINSTALLLOCATION value is shown in the AI table editor, but I can't find a way to edit the "install condition" to change when this property is evaluated. When you right-click and choose to see the custom action for this record...it doesn't display anything editable. Can this action's install condition can be changed in the AI GUI, and what condition value is should be changed to, to preserve the reg key value.
Here is the XML below:
Re: Ensure that patches will not clear the InstallLocation v
I'm not sure why you are encountering this behavior. Can you isolate the behavior in a sample or can you give us a detailed step by step test case scenario so we can try to reproduce and investigate the behavior?
Also, when creating patches please make sure they respect all the patch rules.
