DDoutelMS
Move a Dialog In a Sequence; How?
I've added a custom dialog in the First Time Install section, and need to move it down in the sequence. How do I do this?
Thanks in advance.
DDoutelMS
Re: Move a Dialog In a Sequence; How?
Hi and welcome to our forums,
Unfortunately you cannot drag a dialog on to another position. What you can do is to create a new dialog in the desired position and copy all the controls you added on the current
one, then delete the one that you don't need anymore.
DDoutelMS
Ah, Ok; simple enough. Thanks for the reply!
DDoutelMS
