Thunder
The path Additional File in Prerequisites
How can we get the path to added file in "Prerequisites" -> "Setup File" -> Additional File? This is necessary in Full UI Edit.
Thunder
Re: The path Additional File in Prerequisites
Is there anyone knowledgeable on this forum? Man is considering buying the program, and nobody wants to help him, even answer "no"? Why? Is the answer to my question is so complicated?
Hello and thank you for your interest in Advanced Installer,
Sorry for the delayed response, we usually have an answer in 24 hours but unfortunately, we cannot apply this rule over the week-end.
When you build the package, all additional files are extracted in the same folder as the installation package (MSI or EXE), so you can use the relative path in the command line.
At installation time, the folder extraction path of your files is the one specified in the “Download/extraction folder” field from the “Prerequisites” page.
Because they are in the same folder you can use a relative path.
