bmt22033
Setting version number as build event?
Is it possible to set all or part of the version number of our installer as a build event? We use a command line tool called SubWCRev.exe (part of TortoiseSVN) to stamp the SVN revision number into the version number of our application assembly and we'd like to do something similar for the installer. For what it's worth, we're using AI 10.1 with an Enterprise license. Thank you!
Re: Setting version number as build event?
In order to achieve this you can use the "Set Version Command".
