udonmez
pagefile.sys or hiberfil.sys error
We are getting an error which is "File does not exist: C:\pagefile.sys" as attached when we set a Name:XXX Value: "C:\" at Install Parameters -> Properties
accidentally we have solved error when we set value: [|AI_AIP_FOLDER]
Could you investigate problem, please? Is it a bug?
br
Unsal
Re: pagefile.sys or hiberfil.sys error
Hello Unsal,
I'm not sure why this happens. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
