1) You can change a service name during installation. In order to achieve that you can have an
editBox on the
WelcomeDlg from the
Dialogs page, where the user input a custom name for his service. Select your
editBox and in the
Properties from the right panel, change the
Property Name to something meaningful(e.g. SERVICE_NAME).
Then, when you add a service you will use the
Property Name of your editBox (in our example is SERVICE_NAME) in the Service name field (e.g.
[SERVICE_NAME] ) from the
Service Properties panel.
Please note that the
Service Name field supports
PseudoFormated references.
Formatted references can be used but it is not recommended due to Microsoft Restart Manager limitations.
2) It is possible to install the same service with different names.
