inna_o
multiple instances
I create an msi of enterprise with multiple instances and several features .
In each feature i write to the regystry by instanceId
I installed in the first instance feature a and feature b
and in the second instance i installed feature a
when I am trying to uninstall the first instance it didn't erase the registry of the feature a(which is common in the two instances).
how can I delete the right registry?
Re: multiple instances
You can go in the “Multiple Instances” page and in the “Component” tab add the component that contains your registry from the related feature. In your case you can add for both instance the related component from "feature a". A new component GUID will be automatically generated when a new instance is created. Please take a look on our “Overwrite Components” article.
