ajon13
Updating only changed files
I have a Java application whose Jar file is only .5 MB, but it uses several 3rd party Jar files which total to about 13 MB. What I have been doing is included all of the 3rd party Jar files into 1 Jar file with my Jar. Then I create an .msi file containing the Jumbo Jar and all of the images used by my software. This means in total my .msi file is 32 MB and whenever I change anything my clients all need to download a 32 MB msi file which takes several minutes. I'd like to make it so the 3rd party jar files and any images etc. can be updated on an as needed basis. That way I can change my code and the clients would only download an .msi file that is less than 1 MB. Or if I change an image then, only that image would be updated.
Is this possible?
Re: Updating only changed files
In order to achieve what you want you can make a patch. A patch contains only the difference between two versions of the product.
Also, please keep in mind that in order to successfully create a patch you need to make sure that respect the “Patch Rules”.
