Kost
Visual Issue: Tab background all black
I am running into a visual issue on the installation path setup dialog page. Here is what it looks like:
As you can see there is a visual issue going on in the background. I am running this on Windows Server 2008 R2 x64.
I purposely hid the browser button and disabled the path edit box. I am just not sure why the background is all black which is hiding the text.
When I run this on Windows 7 x64 it looks fine.
Thanks for any help.
Re: Visual Issue: Tab background all black
I'm not sure why you encountered this behavior. Can you please send us the .AIP (project file) so we can investigate it?
Kost
Hi Dan,
Here is my .AIP file:
AIPFile.zip
(530.58 KiB) Downloaded 876 times
Please let me know if you need any more info.
Yes, I can reproduce and confirm this issue. A fix will be available in the next version of Advanced Installer, thank you for bringing it to our attention.
This issue is caused if you select the “Keep original image sizes” option from “Themes” page >> “Settings” tab.
As a workaround you can use “Use individual control stretch settings” or "Stretch images to fit their controls" option .
Let us know if this helps.
Kost
Thanks Dan. I changed my setting to stretch the images to fit the control and that worked.
You're welcome. Glad you got this working.
