VikingCoder
Wrap a ClickOnce application
Hi all,
I am in the process of evaluating Advanced Installer to see if it is possible to wrap a ClickOnce application into an MSI package.
There is a new requirement from the client that all applications that are used by the company be centralized on a "support" website and this website only allows an MSI to be put there.
The idea here is for AI to simply create an MSI that will create desktop shortcut that will point to the .application file on the ClickOnce server (e.g., http://<clickonce server>/<folder>/foobar.application)
Thanks!
Re: Wrap a ClickOnce application
In order to achieve this you can create an Advanced Installer project, then go in the Files and Folders page, select the "Desktop" folder and using the [Shortcut to] toolbar button you can create an "URL" shortcut where you can specify the name of the shortcut, the URL address, etc. Then, you can build and run the project.
Best Regards,
VikingCoder
The technique works :D
But, I can no longer use this technique. :(
It turns out that there is another ClickOnce application developed by another team that is 12 time zones away - but this one installs its desktop shortcut after the ClickOnce is installed; so we can't have 2 desktop icons pointing to same url....back to the drawing board....If you can think of any other idea, I am willing to try it.
Thanks.
I'm afraid I don't fully understand what is your scenario. Can you give us more details (maybe exemplify), so I can think of a better solution?
Best Regards,
