MKutschner
Source file not found:
when I try to install my Product I get an Source file not found error, which you can see in the Error Picture.
This happens when I have an Old Version of my Product installed. The Old Version will be removed correcte. After removing the old Version I get the error.
When I restart the Installation my new Product will be installed correct.
I need to uninstall the old Version, when installed, before I install the new Version, all in one stop without error.
Any ideas that I can fix this problem?
Log File is attached.
Best Regards
MKutschner
Log.txt
InstallLog
(208.25 KiB) Downloaded 579 times
Picture with Error
Picture with Error
Re: Source file not found:
Hi MKutschner,
You can take a look on our Source file not found during upgrade. thread which debates a similar issue.
Best Regards,
MKutschner
thank you for you`re reply.
The suggestions in the thread don`t help me to solve the problem.
Best Regards,
MKutschner
Hi MKutschner,
I'm not sure why you encounter this behavior. Can you please send us the .AIP (project file) so we can take a look on it?
MKutschner
Eusebiu wrote:Hi MKutschner,
Hi Eusebiu,
what`s you`re mail address where I can sent it to.
Best Regards,
MKutschner
Hi MKutschner,
You can send it to support at advancedinstaller dot com.
I looked over your .AIP (project file) and it seems to be configured correctly. Can you please send us a link to download your old and new version of the product to test them and try to find the problem? Also, can you go to the path written in the error dialog and see if the "disk1.cab" file exists there when the error appears (while the error dialog is open)?
MKutschner
Hi Eusebiu,
I replied on you`re mail.
No the File doesn't exist.
Best Regards,
MKutschner
Indeed, I reproduced the behavior, we will investigate the problem and try to fix it in a future version of Advanced Installer.
Meanwhile, can you please try the solution described in the AI 9.6.1 don't extract files to install when reduced UI post and see if the behavior persists (just set the ExtractFilesFirst property to value "1")?
MKutschner
Hi Eusebiu,
thank you for you`re help.
This solved my problem and the installer works now.
Best Regards,
MKutschner
