bchetana
.Net installer class
Hi
I have a version (v1) with .net installer class. I have my coustom code in onAfterInstall method.
In V2 i made some changes in this method.
The problem is when i uninstall the v1 and install v2 , latest dll of .Net Installer Class is getting executed. But when I do upgrade,
its using the old dll any my latest code is not executed in onAfterInstall method.
I have selected "Uninstall old version first and install the new version" option in upgrade page. Still its some how using the cached dll.
How can I over come this problem, ?????
Re: .Net installer class
I'm afraid this behavior is generated by a Windows Installer limitation. As a workaround you can try to remove the older version using the "Uninstall previous versions" custom action. The uninstall custom action should be scheduled before "Wizard Dialogs Stage -> Paths Resolution" action group.
Also, as another solution you can develop your custom action as DTF managed custom action instead of as a .Net Installer Class one.
