Zaheer Falcon
How to make a setup that runs only on a single machine
Hi ,...
I have developed an desktop application in Java Swing and MySQL and need an installer tried Advanced Installer and was sucessfull in making setup file with MySQL i have also added serial keys everything is up and running . But I have one problem since i am distributing my application as a product i need to make the setup in a CD/DVD and the CD should be used only once i mean when once installed the setup with CD/DVD on one computer the same CD/DVD should not be used to run setup file on another computer(Security) . So i am not getting in what way i can do it in Advanced Installer Please Help what can be done to ensure that SETUP will run only on one computer(that is only one machine and the SETUP should not get installed when it is used for second time) ,please help
Re: How to make a setup that runs only on a single machine
I'm afraid we don't have support for this. As a workaround you can use our "Server-side validation" support and configure your server-side serial number validation script to allow only a limited (e.g. 1) number of activation.
Also, as another solution you can try to develop your own custom action which will implement the desired functionality.
