visualsi
Scheduled Task Advanced Settings
We are creating scheduled tasks and would prefer to not have a separate set of "post-installation instructions" for our users to follow.
We need to set the "Delay task for up to (random delay):" parameter when we create a scheduled task. In the current screen for creating scheduled tasks, there is only options to set the very basics for a schedule. Has anyone been able to get to any of the "Advanced Settings" (well, this one in particular)?
Rob
Re: Scheduled Task Advanced Settings
Hi Rob,
I'm afraid that any other customizations you need to be applied on your scheduled task require you to create a custom action, that should run after "Add Resources" group, visible in Custom Actions page.
The following forums thread discusses a similar request.
visualsi
I ALMOST got around this.
By creating the XML file as a "Type = XML File (Windows Installer)", including things like setting the priority to exactly what i want it to be, the Operating System type to what I want, etc. based on user input, this gives me something that can be used as an import file into the task scheduler. It works very well when I manually import it into the scheduler.
Unfortunately, if I go to the "Scheduled Task" section in AI, it will not let me use this file the same way it would let me use a physical XML file.
Is this something that can be changed in AI? Users really hate to get an installer PLUS a separate list of post installer install instructions. Makes it look like a junk installer.
Rob
Hello Rob,
We'll try to add an improvement regarding this in a future version of Advanced Installer. Thank you for your suggestion.
However, as a a workaround, if you want to create a scheduled task using an XML file added in "Files and Folders" page then you can use a custom action which will launch the Schtasks.exe tool with a proper command line. The custom action should be added after "Install Execution Stage -> Add Resources" actions group and should run as deferred with no impersonation.
Please take a look on the "Time Trigger Example (XML)" article which should be useful for you.
