alexm
Generating Installer with Chinese Symbols
Hello everyone!
We have problem with generation installer with Chinese Symbols in Product Name or Company Name.
I have search whole Forum but couldn't find identical issue.
Here is my steps and error:
1) In ProductName or Company Name I use Chinese symbols
12-06-2013 16-58-25.png (47.38 KiB) Viewed 3261 times
2) In Media Settings I set Package Type=Single EXE setup
3) Build Project
4) The, when I try to install generated EXE file I am getting error
12-06-2013 16-16-44.png (27.73 KiB) Viewed 3261 times
Free translation of error from Russian: "Installed Program can't find file disk.cab. Check that this file exist and valid."
I have Advanced Installer 9.5
I don't have this error if My Product/Company name is English or Russian.
Please let me know what can be done in order to generate installer with Chinese symbols.
Re: Generating Installer with Chinese Symbols
This may happen due to a Windows Installer limitation. Windows Installer cannot access a CAB file which is extracted in a path containing non-ansi characters which don't match with target machine operating system locale.
However, in order to avoid this issue you can archive installation files using our LZMA compression option from "Builds -> Configuration" tab.
Also, another solution would be to not use the [|Manufacturer] and [|ProductName] properties in the "Extract Location" field from "Builds -> Configuration" tab, or to include CAB file into the MSI database.
alexm
This is what I need.
Thank you a lot!
Great Software!
